How to connect Groq AI in ONLYOFFICE
28 January 2025By Dasha
The ONLYOFFICE AI plugin seamlessly integrates artificial intelligence into its editors. Among the supported AI models is Groq, a high-performance platform designed to optimize text processing, data analysis, and document creation tasks. Here’s how you can start using Groq AI in ONLYOFFICE.
About Groq
Groq AI is a high-performance artificial intelligence platform developed by Groq Inc., a company specializing in high-performance computing and AI solutions.
It utilizes advanced models like Mixtral 8x7B and Llama 2 70B, optimized for natural language processing and data analysis. With its unique Language Processing Unit (LPU), Groq achieves impressive speeds, generating up to 525 tokens per second with the Mixtral model. This architecture allows for efficient data processing, making it suitable for real-time applications.
Known for its speed and efficiency, Groq AI is a popular choice for organizations that need to handle complex computational workloads, such as natural language processing, real-time analytics, and AI-driven decision-making.
How to connect Groq AI and ONLYOFFICE editors
1. Install the AI plugin
To use Groq AI in ONLYOFFICE, you’ll first need to install and activate the AI plugin. Go to the Plugins tab on the top toolbar. Open the Plugin Manager and find the AI plugin. Click the Install button.
2. Activate the AI tab
After the installation is complete, close the Plugin Manager. Click the Background Plugins button in the Plugins tab and activate the AI function.
3. Connect Groq AI
Once the AI plugin is installed, you can connect Groq to ONLYOFFICE. Open the newly added AI tab on the top toolbar and click Settings to open the AI configuration menu.
Select Edit AI models and click Add.
Choose Groq from the provider list, input your API key, and select the model from the drop-down list. The API key is issued by the AI provider and can be generated on Groq’s official website.
In the row of icons, select the model used for: text, images, embeddings, audio processing, content moderation, real-time tasks, coding help, and visual analysis.
Once set, click OK and close the window.
4. Assign AI tasks
Now, in the AI configuration window, you can assign AI different tasks. In the drop-down list, select the installed AI models that will perform the tasks:
  • Ask AI
  • Summarization
  • Translation
  • Text Analysis
In ONLYOFFICE editors, you can assign different AI providers for different tasks.
Once set up, Groq AI becomes a valuable companion for your document tasks.
How to use Groq AI in ONLYOFFICE editors
Once configured, Groq AI becomes a powerful assistant in your document workflows. Access its features via the AI tab or by right-clicking on selected text. Here are some of the tasks you can accomplish with Groq AI:
  • Get precise answers to queries.
  • Summarize and translate content.
  • Perform advanced text analysis.
  • Generate text and keywords.
  • Explore word meanings and contexts.
  • Write code and more.
Let’s explore one of the use cases.
Generating keywords for an academic research paper
Scenario: you’ve finished writing a research paper on climate change impacts and need to generate keywords for submission to a journal or repository, where indexing is required for academic search engines.
To proceed, select abstract or key sections.
Then right-click and select AI -> Text analysis -> Keywords.
AI will generate keywords based on the selected text and add them to the document.
Here’s the result we got for our report:
Tasks you can perform with Groq
Document Editor
  • Text generation: Create drafts, expand outlines into full text, or brainstorm ideas.
  • Summarization: Condense lengthy documents into key points.
  • Translation: Translate selected text into multiple languages.
  • Proofreading: Detect grammar or stylistic issues and suggest corrections.
  • Keyword extraction: Identify key terms and phrases for indexing or analysis.
Spreadsheet Editor
  • Data summarization: Generate insights from data sets by summarizing trends and patterns.
  • Data categorization: Automatically classify data into relevant groups or categories.
  • Forecasting: Use Groq to predict future trends based on historical data.
  • Natural language queries: Ask questions about your data and get quick answers (e.g., “What was the highest sales figure?”).
  • Formula suggestions: Generate and explain spreadsheet formulas tailored to your dataset.
Presentation Editor
  • Content creation: Generate slide content based on provided topics or outlines.
  • Visual suggestions: Recommend diagrams or visual aids to enhance the presentation.
  • Summary slides: Condense long reports into summarized slide bullet points.
  • Speaker notes: Generate detailed notes for presenters based on slide content.
  • Multilingual slides: Translate slide content into multiple languages for global audiences.
Get started with Groq in ONLYOFFICE editors
Download the ONLYOFFICE suite for Windows, macOS, or Linux, or create a free online account to integrate Groq AI and elevate your document management experience.
START ONLINE           GET DESKTOP EDITORS
