ONLYOFFICE DocSpace Developer: secure document storing and collaboration for your web app users
Welcome ONLYOFFICE DocSpace Developer! It allows you to easily extend the functionality of your own app or service by integrating a secure space for content storing and online collaboration. Learn more details below.
What is ONLYOFFICE DocSpace Developer?
It is a commercial build of the open-source DocSpace solution. It is intended for integration into any commercial software, under your own brand and on your own servers.
Who is DocSpace Developer designed for?
ONLYOFFICE DocSpace Developer will suit you if you need to extend your own web app – such as CMS, project management, messaging, mail, etc. – with a secure space for content storing and online collaboration.
Watch our webinar to learn everything you need about DocSpace Developer:
What will your end users get?
- Various types of rooms for different goals (Collaboration, Form Filling, Public, Custom, and Virtual Data Rooms)
- Ability to work with any electronic content (docs, sheets, slides, PDF and PDF forms, Markdown files, e-books multimedia)
- Enhanced privacy & data security (GDPR compliance, encryption, document access and login control)
- User-friendly and ergonomic UI
- Ability to work on any device
What are the benefits for developers?
- Support for all programming languages
- Any deployment model (SaaS and on-premises)
- Customization (standard branding and White Label)
- Developer Tools
- Ready-to-use integration examples
What is included in Developer Tools?
- Access to open API
- JavaScript SDK to embed the whole DocSpace, separate rooms or files (embedding presets & custom mode)
- Plugin SDK to build and connect your own plugins
- Webhooks to perform custom actions on the side of any application or website you are using based on various events in DocSpace
- OAuth 2.0 for user authorization and further actions like access to files
Which ready-to-use integration examples are there?
- Zoom: direct integration into Zoom Meetings for real-time doc collaboration (based on C#, HTML, CSS).
- WordPress: adding DocSpace rooms or files to the WordPress pages (based on PHP, JavaScript, CSS).
- Drupal: embedding office documents and rooms into Drupal websites (based on PHP, JavaScript, CSS, Twig).
- Pipedrive: working with office files related to Pipedrive Deals in DocSpace rooms (based on Java, TypeScript, JavaScript, CSS, etc.)
- Zapier: automating workflow using zaps for DocSpace and various apps like Asana, Slack, HubSpot, Discord, Trello, Gmail, Pipedrive, Zoom, etc.
Which installation options are provided?
ONLYOFFICE DocSpace Developer is delivered as Docker, DEB and RPM packages for Linux, and EXE package for Windows. The Kubernetes build allows running it in cluster.
What about licensing?
With ONLYOFFICE DocSpace Developer, you get a cost-effective solution tailored to any budget.
If you are planning to use ONLYOFFICE DocSpace for development at first or for internal testing with your system, opt for the corresponding plan with 20 simultaneous connections.
When you are ready to use DocSpace for production to provide it to your end customers, you can choose among various plans of 250/500/1000 or more simultaneous connections. Among additional options you can choose multi-tenancy, multi-server, support for disaster recovery, and more.
You will get support for every step from the ONLYOFFICE experts. 3 support levels are provided to choose from: Basic, Plus, and Premium.
