ONLYOFFICE Documents for iOS v8.1: better integration with DocSpace, paragraph styles, vertical text alignment in shapes, etc.
Good news for iOS users!
Our mobile application for iOS devices ONLYOFFICE Documents has been upgraded to version 8.1. This latest version introduces many enhancements, including improved integration with ONLYOFFICE DocSpace, improved paragraph style management, vertical text alignment in forms, and optimized form field navigation. Keep on reading to learn more about new features and how they can improve your mobile document editing.
Improved integration with ONLYOFFICE DocSpace
ONLYOFFICE Documents v8.1 improves integration with ONLYOFFICE DocSpace. Users can sign in to their ONLYOFFICE DocSpace accounts and access and edit their documents stored in the cloud. This seamless integration ensures that your documents are always synchronized and accessible.
Where to find: Start window -> ONLYOFFICE -> Cloud connection
Enhanced paragraph styles management
The document editor now allows you to create new paragraph styles and delete existing ones that you no longer need. This feature provides greater flexibility and control over your document formatting, ensuring that your documents maintain a consistent and professional appearance.
Where to find: Stylo icon in the top right corner -> Paragraph –> Paragraph style
Vertical text alignment in shapes
ONLYOFFICE Documents v8.1 introduces vertical text alignment in shapes across all editors, including docs, sheets, and slides. This feature allows you to align text vertically within shapes, enhancing the visual appeal and readability of your documents.
Where to find: Stylo icon in the top right corner -> Text –> Text orientation
More convenient navigation through form fields
Navigation buttons for form fields are now conveniently located on the navigation panel, making it easier to move through fields efficiently. This improvement is particularly beneficial when working with complex forms, as it reduces the time and effort required to fill out and review form entries.
Where to find: Upper toolbar
Get ONLYOFFICE Documents v8.1 for iOS
Get the new version of our free ONLYOFFICE Documents app for iOS to work on documents on-the-go:
