ONLYOFFICE Documents 8.0 for Android released: What’s new?
9 February 2024By Vlad
We updated ONLYOFFICE Documents for Android devices to version 8.0. This release brings new features to manage DocSpace rooms, set the correct document language, input bidirectional text, and other much-anticipated benefits.
Create, download, and share DocSpace rooms
We extended the integration with our collaboration platform DocSpace in version 8.0, and now you can manage rooms right from your Android device.
Note: DocSpace account is necessary to perform the actions described below. Create your free account.
Creating new rooms
In ONLYOFFICE Documents app for Android, you can add any type of DocSpace room:
  • Collaboration room to edit office documents collaboratively (editing and viewing available);
  • Custom room with more access permissions for documents (editing, viewing, form filling, reviewing, commenting);
  • Public room for inviting users via external links to view documents without registration.
Where to find: My rooms -> Plus icon
Downloading rooms
Save the progress and files stored in a DocSpace room to your Android device as a ZIP archive.
Where to find: My rooms -> Three dots icon -> Download
Sharing rooms via links
Generate links and share access to documents with other users.
Where to find: My rooms -> Three dots icon -> Info -> Additional links -> Create and copy
Bidirectional text
In version 8.0, we have added support for bidirectional text in documents and presentations. In the upcoming releases, we’re going to add RTL interface and enhance RTL support further.
Conversion to Microsoft formats for editing
From this version on, the app converts text documents, spreadsheets, or presentations to Microsoft-based DOCX, XLSX, and PPTX.
For example, when you upload an OpenDocument text file (ODT) for editing, a dialog window will appear and suggest that you convert the document to DOCX.
Another option is to view the file in the original format.
Set text document language
Switch the language of the text document for correct spellchecking and hyphenation.
Where to find: Document settings -> Document language
Units of measurement in the editors
Change units of measurement to set the relevant ones for your region or specific task (for example, pt and inches).
Where to find: Application settings -> Unit of measurement
Split the page into columns
Arrange text in your documents in columns. This makes information visually appealing and is a formatting standard for some texts, e.g. poetry.
Where to find: Layout -> Column
Image parameters
After uploading an image to your document, you can select it to check and change the parameters.
Stretch the picture, apply text wrapping, replace the image or change the order of several pictures.
Change text orientation in shapes
Have your text displayed vertically or horizontally in any shape.
Where to find: Edit icon -> Text -> Text orientation
Get ONLYOFFICE Documents 8.0 for your Android smartphone or tablet today for free.
DOWNLOAD
You can also download the official app from Samsung Galaxy Store, Huawei AppGallery, Xiaomi GetApps.
