FAQ: all you need to know about ONLYOFFICE Docs 9.1
It’s been a while since ONLYOFFICE Docs 9.1 was released, and now it’s time to answer all the questions that our users had before our team rolled out the new version. Curious to find out what other people want to know about ONLYOFFICE’s new features? Below you will find our answers to more than 20 questions.
Docs 9.1 webinar
If you have a question about ONLYOFFICE Docs 9.1, you can watch our YouTube webinar to learn more about the latest ONLYOFFICE Docs release and its new features:
Haven’t found the answer to your question? Below you can find our answers to what others want to know about ONLYOFFICE Docs 9.1 and further improvements.
You ask, we answer
To make things easier, we have divided all the questions into several categories for better navigation. Let’s dive into it!
ONLYOFFICE PDF Editor
Question: The introduction of new annotation types and a redaction feature sounds like a significant step forward. Could you elaborate on the types of annotations that will be supported?
Answer: Starting from version 9.1, ONLYOFFICE PDF Editor supports shapes like Rectangle, Circle, Arrow and Connected Lines that you can draw directly on your PDF documents. You can customize the color and size of your annotations the way you like on the Comment tab.
Question: The ability to add and manipulate charts and SmartArt directly within PDF files would be an invaluable tool for my workflow. I am curious about the extent of customization that will be available for these elements.
Answer: When adding a chart to your PDF file via the Insert tab, you can choose the desired chart type from the available options, such as Column, Line, Pie, Bar, Area and more. Additionally, you can enable or disable specific chart elements like axis titles, data labels and error bars.
SmartArt in PDFs works the same way as in documents. You can insert the object you like and customize its colour, opacity, line thickness and line type via the Shape settings panel.
ONLYOFFICE Spreadsheet Editor
Question: The mention of being able to set text direction for individual cells is a welcome addition. Are there any other notable improvements to the spreadsheet editor in this release?
Answer: Apart from text direction options for cells, ONLYOFFICE Spreadsheet Editor offers the following improvements:
- Faster formulas: The LOOKUP, VLOOKUP, HLOOKUP, and XLOOKUP functions have been improved for speed and accuracy;
- Interactive content: The spreadsheet editor now supports interactive Content Controls, such as combo boxes, scroll bars, check boxes, spin buttons and list boxes;
- Improved usability: A dedicated Table Design tab, date filters for Pivot Tables and quick sheet renaming are other new features that streamline daily tasks.
Learn about these and other updates in this blog post.
Question: Are the spreadsheet functions highlighted in the parameters as we fill in the formula?
Answer: In ONLYOFFICE Docs 9.1, when you enter a formula, active arguments are highlighted, making it easier for you to track and edit your calculations.
Question: Is this possible to have more options to get data?
Answer: If you mean getting data in spreadsheets, there are currently three options on the Data tab:
- From Local TXT/CSV;
- From TXT/CSV Web Address;
- From Local XML.
If you are looking for another way to get data for your spreadsheets, you can leave your request on our feedback platform.
Question: Do spreadsheet functions have a short explanation of what each parameter should contain/do?
Answer: Sure thing. When you enter a formula via the Formula tab, you will see its description and information about its arguments. If you need to learn more about a formula you are going to apply, just click the Read more button in the Function arguments window, and you will see a detailed breakdown with examples.
Question: How to put a checkbox on the sheet? I can’t find this option.
Answer: Version 9.1 makes it possible to open and view files that already contain content controls. What this means is that you can’t add checkboxes, but can open sheets with checkboxes for viewing.
ONLYOFFICE Desktop Editors
Question: When do you expect the Flatpak to be updated to the new version?
Answer: Usually, the Flatpak version gets updated a few days later after the main release. Stay tuned!
General improvements
Question: Could you provide more information on how the charts, in general, have been enhanced across the suite?
Answer: In version 9.1, the Explosion option for 2D pie and doughnut charts is supported for opening, allowing you to view separated segments. You can also work with external data for diagrams, choosing to embed a file or link to the data source when copying charts between the editors.
Finally, you can enable or disable specific diagram elements like axis titles, data labels and error bars. Learn more in this blog post.
Optimization
Question: Any plans for document saving speed optimization, and for sure overall memory optimization when opening multiple (8-10 spreadsheets or document files)?
Answer: Absolutely! We always try to optimize the performance of our software. In previous versions, we implemented some improvements to reduce file opening time and the ability to pre-load scripts to reduce start time. There will be more optimizations in further releases. Don’t miss them out!
Question: What are the substantial improvements that have been implemented? Are there any considerable changes in performance, taking into account the optimisation of the software in terms of the new features applied?
Answer: When it comes to performance optimization, version 9.1 offers the updated LOOKUP, VLOOKUP, HLOOKUP and XLOOKUP formulas. These are the optimization improvements:
- Improved logic for handling mixed data types to get more accurate results;
- Reduced memory consumption during formula calculations;
- Up to 4x faster exact searches with the VLOOKUP formula;
- A 4-time speed boost for linear searches with XLOOKUP.
Other questions
Question: Will there be an updated version for Android?
Answer: Yes, sure. ONLYOFFICE Documents for Android will be updated soon, providing an AI assistant, text direction options, tables of contents in documents and improved editing tools. Stay tuned!
Question: What advantages or benefits do I have when using ONLYOFFICE over FreeOffice, LibreOffice or WPS?
Answer: ONLYOFFICE Docs is a good alternative to all these solutions. It provides a full set of tools to create, edit and collaborate on documents, spreadsheets, presentations and PDF files, and is equipped with a diagram viewer for Visio files. Due to its native support for DOCX, XLSX and PPTX files and compatibility with all popular files formats, ONLYOFFICE Docs can easily deal with all kinds of office files.
Moreover, ONLYOFFICE Docs seamlessly integrates into any web-based platform and allows you to work with office files on web, desktop and mobile platforms. For more information about the ONLYOFFICE Docs advantages, please visit these pages:
Artificial intelligence
Question: What is your team’s favourite AI platform?
Answer: It’s difficult to say which AI platform is the most popular in our team. At ONLYOFFICE, we use various AI tools and models to improve our productivity. One of the tools we use is ChatGPT. Read this blog post to find out what routine tasks we perform with its help and how it boosts our performance.
Feature requests
In addition to questions about ONLYOFFICE Docs 9.1, we received many requests for new features and tools that our users would like to see implemented in our editors:
- Inserting any object to a document file, such as mp3, mp4, pdf, doc files, etc.;
- Support for Python and SQL in spreadsheets;
- Fully-working Zotero plugin;
- Video trimming and automatic video playback in presentations;
- Direct collapse all/Expand all button for the Heading section;
- Holding CTRL + mouse scroll up/down to resize the Headings section;
- Paragraph sort feature;
- Multi-page view in documents;
- Aligning to a grid;
- Ability to set the font, font size and boldness of Chinese and English texts separately;
- Support for other OCR recognition tools, such as Mineru.
We really appreciate everyone’s feedback and will thoroughly consider each request. If you have another feature suggestion or idea, don’t hesitate to visit our platform available at feedback.onlyoffice.com. Feel free to share your thoughts, ideas and suggestions with us!
Get the latest version of the ONLYOFFICE suite
Want to try all the new features available in version 9.1? Implement the latest self-hosted version on your local server or download the free desktop app for Windows, Linux and macOS:
SELF-HOSTED VERSION DESKTOP APPLICATION
Useful links
ONLYOFFICE Docs 9.1: blog / webinar
ONLYOFFICE Desktop Editors 9.1
ONLYOFFICE Docs 9.1: introducing the new Admin Panel for enterprises
