Simplify your math work with the MathType plugin for ONLYOFFICE
The MathType plugin for ONLYOFFICE is here to make life easier for anyone dealing with mathematical notation. This handy plugin allows you to seamlessly create and insert math formulas right inside your documents. Whether you’re a teacher, student, scientist, or someone who works regularly with equations, MathType can save you time and effort.
Here’s everything you need to know about the MathType plugin for ONLYOFFICE and how it can help you streamline your work.
What is the MathType plugin?
MathType is a versatile tool developed by Design Science for creating and editing mathematical notation. Integrated within ONLYOFFICE, the MathType plugin provides a convenient and user-friendly way to add professional-looking math equations to your text documents, spreadsheets, or presentations.
The plugin also features a variation called ChemType, specialized for creating chemical formulas. This makes MathType suitable for both mathematical and scientific projects.
Key features of the MathType plugin
- Create complex equations: Easily craft mathematical formulas, from simple operations to complex ones.
- Seamless integration: Insert equations directly into your ONLYOFFICE documents with just a few clicks.
- Editable formulas: After inserting, you can double-click on a formula to reopen and edit it.
- Chemical notation support: The ChemType variation allows you to create chemistry-specific formulas.
- User-friendly interface: You don’t need to be a pro to use it. The plugin’s intuitive design makes it accessible to everyone.
How to use the plugin
Getting started with MathType in ONLYOFFICE is a breeze. Here’s a quick step-by-step guide:
- Open your document in the ONLYOFFICE online editors.
- Navigate to the Plugins tab at the top of your document and select MathType (or ChemType if you’re working on chemical formulas).
- A new window will open, where you can start writing your formula using the plugin’s easy-to-use equation builder – by typing or hand-writing.
- Once you’re done, simply click the Insert button. Your formula will immediately appear in the document.
- Need to make changes? Just double-click on the formula, and the MathType editor will pop up, allowing you to tweak your equation as needed.
With these simple steps, you can quickly add professional, error-free formulas into your work.
How to install the plugin
- Go to the Plugins tab in ONLYOFFICE.
- Open the Plugin Manager from the top toolbar.
- Find MathType in the list and click Install.
- Once installed, click the MathType icon in the Plugins tab to launch it.
Please mote: currently, the plugin is only available for the online editors and can’t be used with ONLYOFFICE desktop applications.
Get ONLYOFFICE to use the MathType plugin
The MathType plugin brings powerful equation-building capabilities directly to ONLYOFFICE, simplifying the process of handling math and chemical formulas.
Sign up for a free ONLYOFFICE DocSpace account to try the plugin yourself:
If you have developed a plugin and want to share it with the ONLYOFFICE community, contact us by email or post on our forum.
