How to use Together AI in ONLYOFFICE
29 January 2025By Serge
In one of our previous posts, we discussed connecting Mistral AI to our editors. As part of ONLYOFFICE’s commitment to enhancing our product’s functionality, we are excited to announce the addition of support for Together AI. In this blog post, we will provide a detailed guide on how to harness its powerful features.
What are the benefits of integrating Together AI into ONLYOFFICE?
Together AI is a powerful platform that simplifies the development and integration of AI solutions. It provides tools and resources for tasks like natural language processing, computer vision, and predictive analytics, enabling developers and organizations to build intelligent applications effortlessly. With a focus on scalability and collaboration, Together AI unlocks the full potential of machine learning to enhance workflows and drive innovation.
In this guide, we’ll show you how to connect and use Together AI within the ONLYOFFICE suite.
Prerequisites
To use Together AI within ONLYOFFICE, you’ll need to have the AI plugin installed. If it’s not already installed, follow these steps: Open any ONLYOFFICE editor and navigate to the Plugins tab. From there, open the Plugin Manager, locate the AI plugin, and click the Install button.
The AI plugin will be listed under the Background Plugins section in the Plugin tab. Once activated, a new AI tab will appear on the toolbar.
Connecting Together AI to the AI plugin
First, you need to obtain the API key from the Together AI website. Once you have your API key, follow these steps:
  • Open the AI Settings: After installing the AI plugin, navigate to the AI tab in any ONLYOFFICE editor and click on Settings. This will open the AI configuration window, where you can manage AI models for various tasks.
  • Edit AI Models: In the configuration window, locate the Edit AI Models option in the lower right corner. Click this to access the model management menu, where you can add or modify AI models.
  • Add a New Model: To integrate a new model, click the Add button. This will bring up the Add AI Model menu, displaying a list of available AI providers, including Mistral, OpenAI, Anthropic, and Groq.
  • Select Together AI: From the list of default providers, choose Together AI. Input your API key in the provided field and click the Update Models List.
  • Select a Model: After selecting Together AI, you’ll see a list of models supported by the platform. Choose the model best suited to your needs.
Configuring the Together AI model
Once the setup is complete, you can assign the chosen model to perform specific tasks, and even assign an individual Together AI model to an individual task. This feature enables you to diversify the models used for different tasks. With Together AI, this is especially useful, as it allows you to work with a wide range of available AIs.
The current version of the AI plugin provides the following options:
  • Ask AI lets you interact with the chatbot.
  • Summarization helps you shorten long texts into a few key sentences.
  • Translation allows you to translate text between different languages.
  • Text Analysis helps you analyze words and understand their meanings.
Harnessing the power of Together AI
The Together AI platform offers versatility, allowing you to tackle a variety of tasks using multiple AI models. Paired with the advanced functionality and ease of use of the AI plugin, it empowers you to excel in your tasks.
With this technology, you can:
  • Receive precise answers to your questions;
  • Make diverse requests to the chatbot;
  • Quickly find relevant information;
  • Analyze words and sentences;
  • Generate text and keywords;
  • Summarize and translate texts;
  • Explore the meanings of words and concepts;
  • Write, expand, shorten, or rewrite text;
  • Explain in comments;
  • And much more.
With Together AI integrated into ONLYOFFICE, you can streamline your tasks using tools harnessing the power of advanced AI models. Try ONLYOFFICE and experience the future of productivity today!
Get the ONLYOFFICE editors for your AI assistant
Integrate any AI assistant and streamline your document workflows by creating a free ONLYOFFICE DocSpace account or downloading a free office suite for Windows, Linux and macOS:
START ONLINE                                     GET DESKTOP APP
