Top AI tools for Office suites: explore AI features in ONLYOFFICE
Artificial Intelligence has revolutionized how we work, offering tools to automate repetitive tasks, enhance productivity, and provide valuable insights. Integrating AI directly into document editors makes workflows smoother when generating content, translating, and summarizing information. Let’s explore some top AI tools now available in ONLYOFFICE and see how they transform your document editing experience.
ONLYOFFICE has recently introduced a significant upgrade to its AI capabilities, making your work smarter than ever. Users now have the flexibility to connect any AI assistant—whether it’s OpenAI, Together AI, Mistral, Anthropic, Groq, Google Gemini, DeepSeek, Ollama, xAI, or even local solutions. Let’s explore the new possibilities.
1. OpenAI
OpenAI is a leading company in artificial intelligence research and development responsible for developing GPT (Generative Pre-trained Transformer) models, including ChatGPT. These models are built to understand and generate human-like text, making them suitable for various applications, from content creation to conversation-based queries.
2. DeepSeek
DeepSeek is an advanced AI model designed for in-depth text analysis and content generation. It excels in understanding complex contexts and providing accurate, well-structured responses. DeepSeek is particularly useful for tasks requiring detailed reasoning and high-quality text output, making it a valuable tool for professionals working with extensive documentation and research materials.
Discover our guide on how to use DeepSeek in ONLYOFFICE editors.
3. Ollama
Ollama is a lightweight AI model optimized for local execution, allowing users to run AI-powered tasks directly on their devices without relying on cloud services. This makes it an excellent choice for privacy-conscious users and those needing AI assistance in offline environments. Ollama is designed for efficiency and speed, ensuring seamless performance even on personal workstations.
Learn more about how to connect Ollama to ONLYOFFICE and use its AI models
4. Together AI
Together AI focuses on enhancing team collaboration and ensuring a smooth workflow in shared projects. It excels in processing and organizing content for group tasks, making it a great choice for teamwork-oriented environments.
How to use Together AI in ONLYOFFICE
5. Mistral
Mistral is an open-weight AI model specializing in processing and structuring large volumes of text. Known for its precision, Mistral is particularly useful in industries that deal with extensive data or technical documentation.
How to connect and use Mistral AI in ONLYOFFICE
6. Groq
Groq is an AI solution designed to deliver high-performance processing for complex workloads. It specializes in accelerating machine learning tasks, providing unparalleled speed and efficiency for demanding computational processes.
How to connect Groq AI in ONLYOFFICE
7. Anthropic
Anthropic’s Claude is an AI model designed for safe, precise, and context-aware interactions. It excels in understanding complex queries, generating well-structured responses, and assisting with a wide range of tasks, from content creation to data analysis.
8. Google Gemini
Google Gemini is a powerful AI model developed by Google, designed for advanced reasoning, multilingual understanding, and multimodal capabilities. It seamlessly integrates text, images, code, and more, making it ideal for research, content creation, and complex problem-solving. Gemini excels in providing context-aware and highly accurate responses, making it a versatile AI tool for various professional and creative applications.
9. GPT4All (for Desktop Editors only)
GPT4All is a privacy-focused, open-source AI model designed for offline use. Unlike other AI tools that require internet access, GPT4All works entirely on your local device, making it ideal for users handling sensitive or confidential information.
10. Zhipu Copilot (bonus)
Zhipu Copilot is a separate AI plugin for ONLYOFFICE that brings additional flexibility and functionality to rhe editors. Zhipu Copilot offers users advanced AI-driven capabilities tailored to their unique requirements. It is particularly well-suited for technical and professional environments where customized solutions are necessary.
Read this article to explore all the plugin functionality in ONLYOFFICE.
How to use an AI model in ONLYOFFICE
Here are practical examples of how to use AI for different purposes, with a focus on OpenAI.
Creative writing
Let’s say you need to draft an engaging introduction for a document.
Open your ONLYOFFICE editor and navigate to the AI tab. Click Ask AI, and in the input field, type your request, for example:
“Create an introduction for a document about AI applications in office work.”
The AI will instantly generate a paragraph such as:
You can then insert it into the document and fine-tune or expand the generated content to suit your needs.
Report summarization
Working with lengthy reports? Let AI summarize the key points:
Open the document containing the text you want summarized. Select the text and click Summarize in the AI tab.
In the window that appears, select the target language for the summary and click Summarize. The AI will produce a concise summary.
Once generated, the text will appear in the window next to it where you can review and edit it. Then select a method from the Insert result drop-down list:
- As review
- In comment
- Replace original text
- To the end of the document
Click Insert.
Translation
You’ve received a document in English that needs to be translated into French for a client meeting.
In the AI tab, click Translate and select French. Alternatively, you can use the context menu. Select text and right-click. Go to AI -> Translate -> Translate to French. The text will be replaced with the translation.
Besides, the context menu offers options to make it easier for you to work on texts:
- Fix spelling & grammar
- Rewrite differently
- Make longer
- Make shorter
- Make simpler
- Text and word analysis
Read this guide to know more.
Slide content generation
In the Presentation Editor, you can use AI to generate the structure of slides and text for them.
Open your presentation and switch to the AI tab. Click Ask AI to open the chatbot. Type your request, for example:
“Create an outline for a presentation on AI Tools for Office Suites.”
The AI will instantly generate an example that you can draw on when creating your presentation:
Formula creation
You need a formula to calculate the monthly average sales for a dataset.
In the AI chatbot, type your request:
“Generate the formula for average number for cells E2-E11.“
The bot will generate a formula and all you have to do is copy it and paste it into the desired cell.
Find the right AI for your needs
Each AI model offers unique strengths, and there’s no universal solution for every task. Some models are better suited for creative writing, while others excel at summarizing or processing data. By testing these tools in ONLYOFFICE, you can determine which ones work best for your specific needs. Whether you’re drafting text, collaborating with a team, or working offline, there’s an AI that can help streamline your workflow.
How to customize AI for different tasks in ONLYOFFICE
ONLYOFFICE empowers users to tailor AI tools to their unique workflows. The newly added AI tab in the editors provides easy access to all AI features, allowing you to assign specific tasks to different models based on their capabilities.
For example:
- Use OpenAI for creative content writing and translation.
- Assign Together AI to handle collaborative tasks.
- Apply Mistral for processing and analyzing technical documentation.
- Rely on GPT4All for offline or secure workflows.
- Leverage Groq for high-performance processing of complex workloads and resource-intensive tasks.
- Use DeepSeek for in-depth text analysis and well-structured content generation.
- Run Ollama for local AI execution, ensuring privacy and efficiency without cloud dependency.
- Choose Google Gemini for advanced reasoning, multilingual understanding, and multimodal capabilities.
By default, AI is not connected to editors for security reasons. To do it yourself, follow the steps below.
Step 1. Enable AI in ONLYOFFICE
Launch ONLYOFFICE editors.
Go to the Plugins tab and click the Plugin Manager icon.
Find the AI plugin and click Install.
After the installation is complete, close the Plugin Manager. Click the Background Plugins button in the same Plugins tab and activate the AI function.
Access the newly appeared AI tab in the editor toolbar.
Step 2. Connect AI to editors
In the AI tab, click Settings to open the configuration window.
Select Edit AI models and click +.
Choose an AI provider from the list or add new AI models by entering your API keys.
In the row of icons, select that the model is used for: Text, Images, Embeddings, Audio Processing, Content Moderation, Realtime Tasks, Coding Help, Visual Analysis.
Click OK to save your settings and complete the connection process.
Step 3. Set AI parameters
Open the Settings menu from the AI tab again.
Assign an AI model for tasks, such as ask AI, summarization, translation, or text analysis. If you have connected multiple models, you can select a separate model for each task.
Start using AI by selecting the corresponding options from the AI tab.
Try AI assistant in ONLYOFFICE editors
Discover all AI capabilities in ONLYOFFICE editors yourself online in DocSpace or in Desktop Editors for Windows, Linux, or macOS:
CREATE DOCSPACE ACCOUNT GET DESKTOP EDITORS
Watch our free webinar
Would like to learn more about the updated AI in ONLYOFFICE? Watch our free webinar:
Useful links
Connect AI with ONLYOFFICE editors: Mistral AI / Groq / Together AI / Ollama / DeepSeek
