New plugin in ONLYOFFICE: use CVbuilder to easily create professional resumes in Chinese
A great CV can make a big difference in your job search. The CVbuilder plugin, developed by a student on the Open Source Promotion Plan (OSPP), helps you quickly build resumes using a variety of Chinese CV templates. Let’s walk through the process and see how you can сreate a compelling career profile in just a few steps!
What is the CVbuilder plugin
The CVbuilder plugin offers a selection of pre-designed resume templates to suit a variety of professional needs—whether you’re applying for graduate programs, consulting positions, or tech roles.
Featuring clean, business-oriented designs and a range of color schemes, these templates align with industry-specific standards. The templates can be imported into ONLYOFFICE Document Editor in just one click, allowing you to seamlessly customize and tailor your CV to perfection.
How to use the plugin
To get started, open the ONLYOFFICE Document Editor. If you’re new to ONLYOFFICE, you can register a DocSpace account or download our desktop app for free.
Once you’re set up, follow these simple steps to create your resume:
1. Install the plugin
- Switch to the Plugins tab in the top toolbar.
- Launch the Plugin Manager and search for CVbuilder.
- Click Install to add the plugin.
2. Activate the plugin
Once installed, close the Plugins Manager. In the Plugins tab, click on the CVbuilder icon to activate it.
3. Select a template
When the plugin window opens, you’ll find a variety of CV templates. Choose a template based on industry, style, and color scheme. Use the filter to quickly narrow down your options.
4. Preview the template
Click on a template to preview it in the right-side panel. Check the layout, formatting, and overall design to ensure it suits your needs.
5. Insert and fill out the template
Once you’re satisfied with your choice, click Insert. The template will be added to the ONLYOFFICE editor, and you can customize it with your data.
Here’s the result!
More templates for you
Need more options? Visit the ONLYOFFICE Template Library to find a wide range of templates for documents, spreadsheets, presentations, and PDF forms, as well as additional CV templates if you’re looking for more choices.
Optimize your workflow with ONLYOFFICE
Create, edit and collaborate on docs, sheets, slides, and PDFs by creating a free ONLYOFFICE DocSpace account, or work on documents locally by downloading and installing the free desktop app for your Windows, Linux or macOS:
If you’re a developer and would like to add your plugin to the ONLYOFFICE Plugin Marketplace, feel free to contact us via email or drop us a message at @only_office.
