15 useful JavaScript macros to try in 2025
27 December 2023By Serge
While Microsoft Office has VBA-based macros, ONLYOFFICE goes a step further with JavaScript-based macros, providing more flexibility. In this blog post, we’ll showcase some of the numerous ONLYOFFICE macros that provide a compelling alternative to traditional VBA-based ones.
15 useful JavaScript macros to try in 2024
What is a JavaScript macro?
Macros are powerful tools that automate tasks. ONLYOFFICE employs JavaScript for creating macros covering document, spreadsheet, presentation and PDF editing. These JavaScript macros allow users to automate tasks, enhance document functionality, and customize ONLYOFFICE applications according to their needs.
Why might you need an alternative to VBA macros?
With the ability to write custom JavaScript macros, you can achieve automation, interactivity, and seamless integration with external systems:
  • Automation: JavaScript macros enable users to automate tasks such as formatting, data manipulation, and calculations within documents.
  • Interactivity: Macros can make documents more interactive by responding to user actions or events.
  • Customization: Users can customize the behavior of ONLYOFFICE applications according to their specific needs.
  • Integration: JavaScript macros allow integration with external systems and services, enabling data exchange and communication between ONLYOFFICE and other platforms.
Given that ONLYOFFICE macros utilize JavaScript, and beyond its flexibility, it is an extremely popular language with a vibrant community. There is an abundance of tutorials available, providing comprehensive guidance on how to tackle various tasks with JavaScript. Furthermore, our detailed documentation provides clear explanations of the methods you can use in your JavaScript macros.
Comparing Excel VBA macros to ONLYOFFICE JavaScript alternatives
Highlight duplicates from selection
VBA Excel macro is the following:
Sub HighlightDuplicateValues()
Dim myRange As Range
Dim myCell As Range
Set myRange = Selection
For Each myCell In myRange
If WorksheetFunction.CountIf(myRange, myCell.Value) > 1 Then
myCell.Interior.ColorIndex = 36
End If
Next myCell
End Sub
Unlike the VBA counterpart, our alternative provides more advanced functionality by highlighting duplicate values with unique colors:
(function ()
    // Background color of cells with non-repeating values
    var whiteFill = Api.CreateColorFromRGB(255, 255, 255);
    // The current index of the color range
    var uniqueColorIndex = 0;
    // Color range to highlight duplicate values
    var uniqueColors = [Api.CreateColorFromRGB(255, 255, 0),
        Api.CreateColorFromRGB(204, 204, 255),
        Api.CreateColorFromRGB(0, 255, 0),
        Api.CreateColorFromRGB(0, 128, 128),
        Api.CreateColorFromRGB(192, 192, 192),
        Api.CreateColorFromRGB(255, 204, 0)];
    // Function to get color for duplicates
    function getColor() {
        // If you have chosen all the unique colors, then let's go from the beginning
        if (uniqueColorIndex === uniqueColors.length) {
        return uniqueColors[uniqueColorIndex++];
    // Getting an active sheet
    // Getting selection on the active sheet
    // Map of values in cells with the duplicates number
    var mapValues = {};
    // All cells range
    var arrRanges = [];
    // Going through the selection
        // Getting value from cell
        var value = range.GetValue();
        if (!mapValues.hasOwnProperty(value)) {
            mapValues[value] = 0;
        mapValues[value] += 1;
        arrRanges.push(range);
    var value;
    var mapColors = {};
    // We go through all the cells of the selection and setting the highlighting if this value is repeated more than 1 time
    for (var i = 0; i < arrRanges.length; ++i) {
        value = arrRanges[i].GetValue();
        if (mapValues[value] > 1) {
            if (!mapColors.hasOwnProperty(value)) {
                mapColors[value] = getColor();
            arrRanges[i].SetFillColor(mapColors[value]);
        } else {
            arrRanges[i].SetFillColor(whiteFill);
(no title)
Unhide all rows and columns
This VBA script unhides all rows and columns on the spreadsheet:
Sub UnhideRowsColumns()
Columns.EntireColumn.Hidden = False
Rows.EntireRow.Hidden = False
End Sub
And the same can be done with the JavaScript macro:
(function()
    var indexRowMax = 1048576;
    var n = 1;
    for (let i = 0; i < indexRowMax; i++) {
        activeSheet.GetRows(n).SetHidden(false);
        n++;
    var newRange = activeSheet.GetRange("A1");
    newRange.SetValue("All the rows and columns are unhidden now");
(no title)
You can also hide all the rows and columns by setting the SetHidden parameter to true in this macro:
(function()
    var n = 1;
        activeSheet.GetRows(n).SetHidden(true);
        n++;
    newRange.SetValue("All the rows and columns are hidden now");
If you need more advanced features, we’ve detailed a macro in another blog post that allows you to hide/unhide specific rows and columns.
Highlight greater than values
Here’s a VBA version that highlights greater than value:
Sub HighlightGreaterThanValues()
Dim i As Integer
i = InputBox("Enter Greater Than Value", "Enter Value")
Selection.FormatConditions.Delete
Selection.FormatConditions.Add Type:=xlCellValue, _
Operator:=xlGreater, Formula1:=i
Selection.FormatConditions(Selection.FormatConditions.Count).S
tFirstPriority
With Selection.FormatConditions(1)
.Font.Color = RGB(0, 0, 0)
.Interior.Color = RGB(31, 218, 154)
End With
End Sub
The same task can be tackled with an ONLYOFFICE JavaScript macro, even using fewer lines of code:
(function ()
        if (value > 5) {
            range.SetFillColor(Api.CreateColorFromRGB(255, 255, 0));
(no title)
Despite having fewer lines of code, our alternative offers better versatility. For instance, by changing the condition of the if statement, we can:
  • Highlight lower than values:
(function ()
        if (value < 5) {
  • Highlight negative numbers:
(function ()
        if (value < 0) {
  • Highlight cells with specific text:
(function ()
        if (value == 'text') {
More useful JavaScript macros to try
  1. A JavaScript macro to add indexes to a selection in ONLYOFFICE spreadsheets
    Sometimes the default indexing just won’t do. That’s where our time-saving JavaScript macro comes in. It’ll neatly index all the rows in your selection, making your spreadsheet workflow a whole lot simpler.
  2. A JavaScript macro to copy spreadsheets
    Editing spreadsheets can be tricky, especially when handling multiple spreadsheets with similar data. This JavaScript macro copies data from one spreadsheet to another, and helps you handle large spreadsheets easily.
  3. A JavaScript macro to scale images in presentations
    Handling images in presentations often involves time-consuming manual resizing, especially when dealing with a large number of visuals. This JavaScript macro resizes all the images in your presentation.
  4. A JavaScript macro to import hyperlinks into a spreadsheet
    Hyperlinks can greatly enhance the aesthetics and functionality of your spreadsheets, making it effortless to access crucial resources within your documents. This JavaScript macro imports hyperlinks by extracting link data from another spreadsheet.
  5. A JavaScript macro to find company logos
    Given the many logos out there, discovering logo references can be a bit tricky these days, potentially leading to confusion. Yet, with ONLYOFFICE macros, you can make this process automatic. This JavaScript macro can simultaneously retrieve several logotypes from an external API and insert them into your spreadsheet.
  6. A JavaScript macro to generate personalized gender-based greetings
    Addressing people correctly is crucial in communication as it shows respect, inclusivity, and professionalism. This JavaScript macro utilizes the Genderize.io API to generate proper personalized greetings.
  7. A JavaScript macro to track orders on Shopify
    In this day and age, E-commerce has become a valuable tool to break down geographical barriers and facilitate the constant stream of income. Therefore managing and tracking order information is a vital part of a successful business strategy. This JavaScript macro retrieves order data from Shopify and inserts it into a spreadsheet.
  8. A JavaScript to macro to import CSV and TXT data into your spreadsheet
    Storing tabular data in a CSV format is very practical in many ways, which makes this type of file extremely popular. ONLYOFFICE Docs allow importing local CSV and TXT files. This JavaScript macro will help you tackle importing remote CSV and TXT files.
  9. A JavaScript macro to replace words in the document
    Editing documents is an essential part of our routine, and we constantly look for tools to streamline repetitive actions.  This JavaScript macro replaces words in the document within a selection.
  10. A JavaScript macro to create a table from the numbered list
    When managing documents, transforming numbered lists into tables can significantly enhance readability and presentation. This JavaScript macro transforms numbered lists into structured tables.
  11. A JavaScript macro to copy columns into separate spreadsheets
    By using ONLYOFFICE macros, you can streamline complex tasks, reducing hours of work to a single click. This  JavaScript macro copies specific columns to designated sheets.
  12. A JavaScript macro to remove duplicates in the selection
    This JavaScript macro removes duplicates from the spreadsheet selection. It helps you to get rid of duplicate entries, making your data clean and accurate with a simple and efficient solution that enhances your overall spreadsheet experience.
ONLYOFFICE macros are flexible and powerful tools, capable of not only mimicking the functionality of VBA macros but also surpassing them.
We also encourage everyone to leverage our ONLYOFFICE API and create your own fascinating macros. If you have any questions or ideas, don’t hesitate to reach out to us. We are open to discussion and collaboration.
