ONLYOFFICE releases official connector for Odoo
Our integration app for Odoo is now available. It allows editing and collaborating on office files within Odoo Documents. Find out more details below.
About Odoo
Odoo is a Belgian suite of business software tools which cover CRM, e-commerce, billing, accounting, manufacturing, warehouse, project and inventory management.
Odoo provides an open-source community version as well as an enterprise version with extra features and services. The suite is available for both on-premises and ready-to-use SaaS environment.
ONLYOFFICE app and its features
ONLYOFFICE app allows working with office documents uploaded in Odoo using ONLYOFFICE Docs. Actually, you can launch the editors in any Odoo section where you can upload/attach files.
For example, you can edit the attached deal notes in the Sales section:
Or open chat attachments in the Discuss section:
Available actions and supported file formats:
- edit text documents, spreadsheets, and presentations (DOCX, XLSX, PPTX);
- collaborate on documents with your colleagues in real time;
- edit form templates in DOCXF;
- read PDF files;
- open other office file formats for viewing, including RTF, TXT, CSV, etc.
How to install the app
ONLYOFFICE app is available in the Odoo Apps Store. You can easily install it from the admin panel. To do so:
- Log into your existing Odoo account or sign up for a new account.
- Go to the Odoo administration panel and click Apps on the top menu bar.
- Search for ONLYOFFICE in the Apps catalog.
- Click the Install button.
Manual app installation is also possible – please check these instructions.
Please note: along with the integration app, you will need an instance of ONLYOFFICE Docs. You can install the self-hosted version of the editors (free Community build or scalable Enterprise version), or opt for ONLYOFFICE Docs Cloud which doesn’t require downloading and installation.
How to configure the connector
To adjust the app settings within your Odoo, go to Home menu -> Settings -> ONLYOFFICE.
- Document Server URL: Specify the URL of the installed ONLYOFFICE Docs or the address of ONLYOFFICE Docs Cloud.
- Document Server JWT Secret: JWT is enabled by default and the secret key is generated automatically to control document access on the back-end. You can specify your own secret key in this field. In this case, you also need to specify the same secret key in the ONLYOFFICE Docs config file to enable the validation.
- Document Server JWT Header: Standard JWT header used in ONLYOFFICE is Authorization. In case this header is in conflict with your setup, you can change the header to the custom one.
Useful links
Integration app for Odoo: Odoo Apps Store / GitHub
Get ONLYOFFICE Docs: self-hosted / in the cloud
