Translate better in ONLYOFFICE with Google Translate
11 December 2020By Sergey
Do you often work with documents in different languages? ONLYOFFICE Docs 6.1 makes it easier to translate words right within your doc without having to switch between various apps — the new version brings in Google Translate. Read this post to find out more.
Why Google Translate
The translation feature has been available in ONLYOFFICE editors for a long time owing to the use of a third-party plugin provided by Yandex. However, we received a lot of requests from our users who prefer Google Translate. After weighing up the pros and cons, we decided to replace the current plugin. Starting from version 6.1 of ONLYOFFICE Docs, you can translate using Google Translate.
The Google Translate plugin helps you get the meaning of any unknown word or phrase in a foreign language within seconds and supports a lot of different languages.
The new plugin is located on the Plugins tab of the top toolbar.
How to use Google Translate
The new plugin is very easy to use. To translate a word or even a whole sentence, just follow these steps:
  • Select the required text;
  • Switch to the Plugins tab and choose Translator;
  • Choose the language you need from the drop-down list;
  • The text will be translated into the required language.
If you are not happy with Google services and don’t want to use Google Translate, please read this guide to find out how to disable it.
About Google Translate
Google Translate is a free neural machine translation service developed by Google that allows translating text from one language into another. It offers a website interface, a mobile app for Android and iOS, and an application programming interface that helps developers build browser extensions and software applications. Launched in 2006, now the service supports more than 100 languages.
