ONLYOFFICE-Nextcloud integration: How to protect documents with watermark
ONLYOFFICE integrated in your Nextcloud allows you to insert watermarks into your docs to protect any confidential or sensitive information they might contain. Read on to learn the details.
To secure your documents, spreadsheets and presentations by embedding a watermark:
- log in to your Nextcloud instance as an admin;
- go to the ONLYOFFICE settings page;
- scroll down to the Secure view settings section;
- check the Enable watermarking box.
You are able to replace the default watermark text with your own using the supported placeholders {userId} and {date}. These placeholders will be displayed individually for each user when opening a file.
You can also define groups to differentiate users for whom the watermark will be displayed as well as select types of shares where the watermark has to be shown.
Once you are ready, just save the settings.
Good job! Now your documents are protected with a watermark:
Check this beginner’s guide on ONLYOFFICE-Nextcloud integration.
Get ONLYOFFICE online editors for your Nextcloud -> Fill in this form or Download the free version.
Download the latest version of the ONLYOFFICE connector from the Nextcloud App Store.
Read the detailed API documentation on ONLYOFFICE-Nextcloud integration.
If you have any questions or suggestions, use the comment section below or tweet us at @only_office. Your feedback is always appreciated!
