ONLYOFFICE Documents 9.4 for Android released: What’s new?
2 June 2026By Vlad
0:00 / 1:44
Summary
The new release of ONLYOFFICE Documents 9.4 for Android introduces several exciting features, including asynchronous collaboration mode, new slide designs, a redesigned toolbar, and performance enhancements. Users can now manually control autosave for cloud files, create colorful slides with 25 new designs, and sort comments by date and author for improved collaboration.
  • Asynchronous collaboration mode is now available.
  • Users can create slides with 25 new designs.
  • The toolbar has been redesigned for efficiency.
  • Comments can be sorted by date and author.
  • Performance enhancements provide a smoother experience.
We updated ONLYOFFICE Documents for Android devices to version 9.4. This release contains asynchronous collaboration mode, the new slide designs from Docs 9.4, redesigned toolbar with an expanded set of tools, and performance enhancements.
Disable autosave for cloud files
Apply changes manually for full control during collaboration. You can hide data being entered before tapping the Save button.
Where to find: Tap (three dots) -> Autosave. To manually save a file, turn off the autosave toggle, and click Save.
Use new slide designs
Create colorful slides with 25 new designs for your slides inspired by galaxy, retro gaming, minimalism etc.
Where to find: Slides -> Theme
Adjust order and visibility of comments
Sort the comments in your documents by date and author. Choose what comments should be visible — active, solved or both.
Where to find: Collaboration -> Comments -> three dots icon -> Show comments -> Sort by All, Open, or Resolved.
Other updates and improvements
Meet the redesigned toolbar with an expanded set of tools for more efficient editing. We also added internal improvements for smoother app performance.
Get ONLYOFFICE Documents 9.4 for your Android smartphone or tablet today for free.
DOWNLOAD
You can also download the official app from Samsung Galaxy Store, Huawei AppGallery, Xiaomi GetApps.
