ONLYOFFICE connector v9.10.1 for ownCloud: diagram viewing, new supported file formats, live-viewing mode for shared documents and more
Good news for ownCloud users!
Our official integration app for ownCloud has been updated to version 9.10.1. With the updated app, you can now view diagrams, work with more file formats, enable the live-view mode for files shared via public links, insert SVG images and more. Read this article for more information about this release.
Open diagrams for viewing
The version 9.10.1 release brings the functionality of ONLYOFFICE Diagram Viewer to the ownCloud platform, making it possible to open mind maps, flowcharts, organizational charts, journey maps and other popular types of diagrams. Specifically, the updated integration app now supports .vsdx, .vssx, .vstx, .vsdm, .vssm and .vstm files.
Open and edit new file formats
With version 9.10.1, ownCloud users can enjoy extended format compatibility. What this means is that now you can:
- Open .odg and .md documents for viewing;
- Edit .xlsb spreadsheets without conversion.
Enable the live-viewing mode for shared documents
The updated ONLYOFFICE connector makes collaborative work easier, allowing you to enable the live-viewing mode for documents shared via external links. When this option is enabled, external users can see all changes made by other collaborators in real time, even if they are only viewing the shared document.
Read our API documentation to learn how live-viewing in ONLYOFFICE works.
Insert .svg images
Another useful feature in the updated ONLYOFFICE and ownCloud integration is the ability to insert .svg images into your documents, spreadsheets and presentations. To add one, access the Insert tab, click Image and choose the desired option — Image from file, Image from URL or Image from storage.
Set the default interface theme
With the updated integration app, you can configure the default interface theme via the ONLYOFFICE customization settings, choosing between the Same as system, Light and Dark options.
Other updates
There are also some other changes that you can find in version 9.10.1:
- When the connection is restored, opened files refresh automatically;
- The outdated customization_goback and toolbarNoTabs settings were removed;
- When you open the ONLYOFFICE settings page, and there is an error in the connector’s configuration, you will see the corresponding message.
Check the full changelog on GitHub.
Get the updated connector
Download the latest version of the ONLYOFFICE connector from the ownCloud marketplace and try all the new features within your ownCloud platform:
Watch this video to learn how to integrate ONLYOFFICE Docs with ownCloud:
Frequently asked questions (FAQ)
Q: Is the ONLYOFFICE integration app for ownCloud free?
Yes, it’s free. You can get it from the ownCloud marketplace or GitHub.
Q: Besides the integration app, what else do I need to install to try this integration?
You need to either install the self-hosted ONLYOFFICE Docs or sign up for its cloud-based version.
Q: Can I check how the ONLYOFFICE and ownCloud integration works before implementing it?
Sure, you can. You just need to install the ONLYOFFICE integration app and enable the Connect to demo ONLYOFFICE Docs server option in its settings. This will allow you to connect to a demo server for 30 days and check how the integration works for you.
Q: Where do I find guides on how to install and configure the ONLYOFFICE and ownCloud combo?
You can find more information in our Help Center and API documentation.
Useful links
Get the ONLYOFFICE connector: ownCloud marketplace / GitHub
Get ONLYOFFICE Docs for your ownCloud instance: server / cloud
User guides: Help Center / API documentation
