ONLYOFFICE DocSpace Developer: version 3.1 & API updates
ONLYOFFICE DocSpace Developer 3.1 is here with multiple feature updates and powerful API enhancements. Discover all the details below.
The latest release comes packed with powerful new features to boost productivity and collaboration of your end users.
Key highlights include:
- role-based form filling in Virtual Data Rooms for added security and streamlined workflows;
- reusable room templates to save time;
- improved guest management for seamless cooperation with external users;
- enhanced file management with quick sharing of PDF forms, better version control, and smoother operations.
Get the latest version of ONLYOFFICE DocSpace Developer:
DocSpace API updates
The recent updates to the DocSpace API introduce powerful tools to simplify API interactions and enhance user management.
API Keys
A new endpoint allows you to create user API keys directly through API requests. This feature simplifies secure integration and user-specific control. Learn more
OAuth 2.0
The API now supports OAuth 2.0 authorization. This feature is essential for implementing more secure and scalable authentication flows across applications. Explore the OAuth 2.0 setup process
Webhook triggers
You can retrieve a full list of triggers for a webhook using the new method. These triggers provide actionable events to automate workflows and system integrations. Learn more about webhook integration
Plugins SDK samples
Streamline the plugin development process – create, code, build, and upload custom plugins to DocSpace using the newly added ready examples. Check samples
