ONLYOFFICE connector for Nuxeo v3.0: PDF form creation and editing
1 April 2025By Dasha
The latest update of the ONLYOFFICE connector for Nuxeo is now available. Version 3.0.0 introduces PDF editing features, a new format support for fillable forms, and a range of new settings to enhance your document management experience. Read on to learn more about all the changes.
Create, edit, and co-author PDF files
Nuxeo users can now open and edit PDF files using ONLYOFFICE PDF Editor. This functionality enables users to perform the following actions:
  • Edit text;
  • Add, rotate, and delete one or multiple pages and rearrange them;
  • Insert and modify images, tables, graphics, shapes, TextArt, hyperlinks, equations, etc.;
  • Switch between the Editing and Commenting modes;
  • Add annotations via text comments, callouts, pen, and highlighter.
Discover all the functionality in this video:
With the new version of the connector, users can collaborate on PDF files using two modes:
  • Fast mode enables real-time collaboration, where changes are instantly visible to all users working on the document.
  • Strict mode allows users to make changes privately, which become visible to others only after clicking Save. This mode is ideal for maintaining control over when edits are shared.
To switch modes, open the File menu, navigate to Advanced settings, and select your preferred mode under the Collaboration section.
Build fillable forms in PDF
With the latest update to the ONLYOFFICE connector for Nuxeo, you can create and work with PDF forms directly from the start. This means you no longer need to create forms in another format and convert them to PDF.
The new version of the ONLYOFFICE connector for Nuxeo allows you to create and edit fillable PDF forms. You can add various field types from the Forms tab:
  • Text fields
  • Combo boxes
  • Dropdown lists
  • Checkboxes
  • Radio buttons
  • Images
  • Signature fields
  • E-mail addresses
  • And others
Other improvements
The version 3.0 of the ONLYOFFICE connector for Nuxeo also comes with other updates:
  • Default empty file templates
  • Migration to Java SDK
  • Shardkey parameter
  • Default JWT token lifetime configuration
  • Shortened addresses for conversion
  • Enhanced verification of connection settings
Find the full changelog on GitHub.
Get the updated connector for Nuxeo
Download the latest version of the ONLYOFFICE Connector for Nuxeo from GitHub and start editing documents, forms, and PDFs directly within your Nuxeo platform:
GET THE CONNECTOR
