Smarter and smoother: discover the new version of the AI Plugin in ONLYOFFICE
We’re excited to introduce the latest version of the AI plugin in ONLYOFFICE, which brings smarter interactions, a more intuitive design, and even greater flexibility right into your documents. Whether you’re drafting content, translating, rewriting, or exploring ideas, this upgrade makes working with AI smoother, faster, and easier than ever. Let’s take a look at what’s new and how it can supercharge your productivity.
What is the AI plugin in ONLYOFFICE?
The AI plugin is your built-in writing and productivity assistant available in ONLYOFFICE documents, spreadsheets, and presentations. It connects to popular AI models like ChatGPT, Claude, Gemini, Mistral, DeepSeek, and even local providers such as Ollama and GPT4ALL. You can assign different models to specific tasks like content generation, translation, summarization, grammar correction, and more — all from within your editor, with no need to switch apps.
What’s new in the latest release?
This version introduces a series of quality-of-life improvements and interface upgrades designed to help you interact with AI more comfortably and effectively.
Chat window docking: left panel or floating
You now have the option to pin the chat window to the left sidebar or keep it floating within the document area. This gives you more flexibility depending on your workspace preferences or screen layout. Switch between the two modes with a single click, and keep your document and AI assistant in perfect sync.
New start buttons in the chat window
A redesigned start interface in the chat window makes it easier to begin a conversation with your AI assistant. Pre-configured prompts and clearer controls help guide your interaction, whether you’re looking to generate text, ask a question, or run an advanced task.
Smart action buttons right in the editor
We’ve added a set of quick processing buttons that appear directly within the document editor when AI is in use:
- Generate new – instantly create a new version or variation
- Copy – save the output with one click
- Replace original text – substitute your selected content with the AI result
- Insert result – add the AI response into your document
- In comment / Review – insert output as a comment or suggestion
These new controls make editing, reviewing, and experimenting with content much faster — no more copy-paste loops or switching between tabs.
Bug fixes and interface enhancements
This update also delivers numerous bug fixes and refinements to the user interface. The AI panel is now cleaner, more intuitive, and more responsive. Tooltips, layout spacing, and performance have all been optimized to ensure a seamless user experience.
How to start using the updated AI plugin
- Open ONLYOFFICE Document Editor.
- Go to the Plugins tab and launch the Plugin Manager if you’ve used any AI helper within the editor. Otherwise, simply hit the Update button to use the new version of the AI plugin.
- Then go to the Background plugins tab and choose AI.
- After that, open up the corresponding tab to edit settings and assign tasks.
- To configure, hit Edit AI models and add your preferred one (OpenAI, Mistral, DeepSeek, Claude, etc.).
- Fill in the blanks and specify the API key
- Choose how you’d like to use this model and press OK.
Start chatting, processing text, or assigning tasks — it’s that easy!
Watch the video below for more detailed instructions:
If you’d like to add a custom provider, please consult our comprehensive guide.
With these new features, the AI plugin in ONLYOFFICE becomes even more integrated into your workflow; it’s an active part of your document editing environment. You can brainstorm ideas, translate content, fix grammar, and polish writing without ever leaving your file.
And for those working in secure environments or with specific data policies, ONLYOFFICE allows you to connect local AI models for full data privacy and control.
Ready to try it?
Update your plugin and experience the new way of working with AI in ONLYOFFICE editors. Whether you’re a writer, student, educator, marketer, or developer, this assistant is built to support your work, your way.
Useful links
Connect AI with ONLYOFFICE editors: Mistral AI / Groq / Together AI / Ollama / DeepSeek / Anthropic / LocalAI / Gemini AI
