ONLYOFFICE Documents v8.1 for Android: improved DocSpace support, LDAP authentication, more options for interface and sharing
Great news for Android users!
Our mobile application for Android devices, ONLYOFFICE Documents, has been upgraded to version 8.1. This latest version brings several enhancements, including improved integration with ONLYOFFICE DocSpace, LDAP authentication, optimized text orientation in autoshapes, new interface and PDF sharing. Keep reading to discover more about these new features and how they can improve your mobile document editing experience.
Improved DocSpace support
ONLYOFFICE Documents v8.1 takes integration with ONLYOFFICE DocSpace to the next level. Users can now sign in to their ONLYOFFICE DocSpace accounts to access, edit and share their cloud-stored documents within different types of rooms. This enhanced integration provides additional collaboration features, ensuring your documents are always accessible to your team, clients, and collaborators.
New features include:
- Sharing documents directly from storage
 - Adding third-party storages to rooms
 - Filtering by forms and form templates
 - Changing room owners
 - Inviting new users manually via email or from a list
 - Selecting individual users or groups of users
 - Updated interface and context menu for Public and Custom rooms
 - Enhanced filters for archived or deleted items.
Experience these improvements to streamline your document management and collaboration.
Where to find: Start window -> Rooms
LDAP authentication
The updated login page enhances security and user convenience by integrating LDAP (Lightweight Directory Access Protocol) authentication directly into the login screen. This feature allows users to authenticate with their existing domain credentials, streamlining access to ONLYOFFICE services without the need for separate login credentials.
By enabling LDAP integration, teams can ensure seamless authentication across their network, maintaining centralized user management and security policies. This not only simplifies user access but also enhances data security by leveraging existing domain authentication protocols. Additionally, administrators have greater control over user permissions and access rights, enhancing overall system management efficiency.
Where to find: Portal login page
New interface and PDF sharing
The ONLYOFFICE Documents app for Android has introduced several new features to enhance the PDF form-filling experience:
- Easier navigation: use arrows to navigate between fields that need to be completed.
 - Intuitive form filling: fields that need to be filled in are highlighted, making it easy to see where input is required.
 - Redesigned interface: improved radio buttons and check boxes for a smoother user experience.
 - Guidance features: pop-up tooltips provide better navigation and help with filling in forms.
 - Context menu options for adding images: choose from the gallery, take a picture, or add a link for more versatile form completion.
After completing your work with a PDF form, you have several options:
- Save options: save the form to a portal in the desired location and choose a folder to save it in.
 - Export and share: export the form and share it with your teammates.
 - Add to favorites: add the form to favorites if you plan to use the template frequently.
These enhancements make working with PDF forms in the ONLYOFFICE Documents app for Android more efficient and user-friendly.
Where to find: PDF Editor -> File menu
Text orientation in autoshapes
ONLYOFFICE Documents v8.1 introduces redesigned text alignment within autoshapes. This enhancement enables you to align text within shapes, improving document aesthetics and readability.
When editing text in a shape, you can apply following options:
- Horizontal Text
 - Rotate Text Up
 - Rotate Text Down
This works for text in autoshapes and text in cells within a Spreadsheet Editor.
Where to find: Autoshape -> Context menu –> Text orientation
Other improvements
At ONLYOFFICE, we are dedicated to continuous improvement, striving to create the best possible app for our users. We are constantly refining and enhancing our features, functionality, and user experience to ensure that ONLYOFFICE remains your top choice for productive and efficient document management. Here below you can find other improvements in the current release:
- New placeholders in the document manager
 - General performance and stability improvements
Your feedback is invaluable to us as we innovate and evolve, making sure our app meets your needs now and in the future. Do not hesitate to tweet us and share your point of view.
Get ONLYOFFICE Documents v8.1 for Android
Download the latest version of our free ONLYOFFICE Documents app for Android to work on documents anytime, anywhere:
