ONLYOFFICE DocSpace plugin v1.1.0 for Drupal: embedding several rooms and files to Drupal pages, DocSpace widget settings and more
Great news for Drupal users!
We have updated the ONLYOFFICE DocSpace plugin for Drupal to version 1.1.0 bringing some useful improvements. Read this article to learn more about the new version.
Embedding several DocSpace rooms and files to Drupal pages
The newest version of the ONLYOFFICE DocSpace plugin for Drupal allows you to add several DocSpace rooms or files at once to your Drupal page when creating a new article.
![ONLYOFFICE DocSpace plugin v1.1.0 for Drupal: embedding several rooms and files to Drupal pages, DocSpace widget settings and more](https://static-blog.onlyoffice.com/wp-content/uploads/2024/06/26101204/Embedded-DocSpace-room-and-a-file.png)
With the new DocSpace widget settings, you are now able to choose whether to display a file added to a Drupal page in the editor frame (available for further editing) or in the embedded mode (available for viewing only). You can also decide which theme, Dark or Light, is turned on in the ONLYOFFICE editors and DocSpace rooms.
![ONLYOFFICE DocSpace plugin v1.1.0 for Drupal: embedding several rooms and files to Drupal pages, DocSpace widget settings and more](https://static-blog.onlyoffice.com/wp-content/uploads/2024/06/26102227/DocSpace-format-settings.png)
To access the DocSpace widget settings, go to Structure on the top toolbar, then choose Content types, find the desired type (in our case, Article) and click on Manage fields. After that, you need to switch to the Manage Display tab, find DocSpace and click the gear-wheel icon.
![ONLYOFFICE DocSpace plugin v1.1.0 for Drupal: embedding several rooms and files to Drupal pages, DocSpace widget settings and more](https://static-blog.onlyoffice.com/wp-content/uploads/2024/06/26102413/Structure-types.png)
That’s it. Now you can opt for the desired mode and theme as well as establish the width and height parameters for DocSpace elements. Click on Update and don’t forget to click on the Save button at the bottom of the page.
Improved visualization of DocSpace rooms
If you make the ONLYOFFICE frame wide enough via the Height and Width parameters in the widget settings, all embedded DocSpace rooms will have a table structure with Name, Size and Type. This way, interaction with office files becomes more comfortable for the visitors of your Drupal website as they can easily see what kind of file they are going to open, its format and its size.
![ONLYOFFICE DocSpace plugin v1.1.0 for Drupal: embedding several rooms and files to Drupal pages, DocSpace widget settings and more](https://static-blog.onlyoffice.com/wp-content/uploads/2024/06/26102639/Room-display.png)
Other updates
- Light interface theme for DocSpace in the admin panel;
- Hidden Sign out button for DocSpace;
- Hidden pop-up name requests for anonymous users in the embedded editors.
Get the updated ONLYOFFICE DocSpace plugin for Drupal
Create rooms, store and manage office files, invite other users for real-time collaboration and embed documents and folders into your Drupal website with the updated ONLYOFFICE DocSpace plugin. Get it now from the official Drupal Project Page:
Watch this webinar to get familiar with the latest version of the ONLYOFFICE suite, version 8.1, and its new features, including an updated PDF editor:
Useful links
ONLYOFFICE DocSpace plugin for Drupal: Drupal Project Page / GitHub
