ONLYOFFICE Docs plugin v2.0 for WordPress: multisite support, PDF forms, anonymous access, and more
We updated the ONLYOFFICE Docs plugin for WordPress to version 2.0.0. It supports the multisite feature, PDF form filling and annotating, brings file embedding as a link and access for anonymous users on public posts. Read on to explore all the improvements.
Multisite support
WordPress Multisite enables you to create several instances of WordPress managed within one installation.
From now on, the ONLYOFFICE Docs plugin supports this feature as well. Thus, Super Admin can configure the plugin for all sites at once, or allow site administrators changing the connector settings for their sites.
As a site administrator, you can inherit the network settings for the ONLYOFFICE Docs plugin or configure it yourself in case Super Admin checked the corresponding option.
Where to find: Admin dashboard -> ONLYOFFICE Docs -> Settings
Working with PDF
Open PDF files uploaded to your WordPress via admin dashboard for form filling and annotating:
- fill out interactive fields;
- highlight, underline and strikethrough text;
- leave comments;
- draw different objects and lines with the built-in drawing tools.
Where to find: Admin dashboard -> ONLYOFFICE Docs -> Files
File embedding as a link & updated block settings
Along with inserting files to the published pages via the editor frame, embed documents as a link.
Where to find: ONLYOFFICE Docs block settings -> Document view -> Link
You can decide whether to show the Open in ONLYOFFICE button next to the file link or not.
Moreover, you can easily align the embedded file on the page as you need and adjust its width and height (the latter option is applicable when inserting the editor frame).
Access for anonymous users
The option to embed a document as a link also allows unauthorized users to open the file attached to a public post for viewing by clicking the file link or button.
Updated formats support
For viewing:
- DJVU, DOC, DOCM, DOCX, DOCXF, DOT, DOTM, DOTX, EPUB, FB2, FODT, HTM, HTML, MHT, MHTML, ODT, OFORM, OTT, OXPS, PDF, RTF, STW, SXW, TXT, WPS, WPT, XML, XPS
- CSV, ET, ETT, FODS, ODS, OTS, SXC, XLS, XLSB, XLSM, XLSX, XLT, XLTM, XLTX
- DPS, DPT, FODP, ODP, OTP, POT, POTM, POTX, PPS, PPSM, PPSX, PPT, PPTM, PPTX, SXI
For editing:
- DOCM, DOCX, DOCXF, DOTM, DOTX
- XLSM, XLSX, XLTM, XLTX
- POTM, POTX, PPSM, PPSX, PPTM, PPTX
Other fixes and improvements
- Copy URL button in the Files section to easily get the editor link;
- displaying the onlyoffice-wordpress-block component in the Gutenberg editor;
- stub for the onlyoffice-wordpress-block that shows error information in case ONLYOFFICE Docs is not accessible or the file is not found.
Get the updated ONLYOFFICE Docs plugin for your WordPress
Make sure you have access to all the new features by getting the latest app version from the WordPress Plugin Directory:
Useful links
ONLYOFFICE Docs: on-premises / cloud
