ONLYOFFICE connector v9.1.1 for ownCloud: PDF forms and annotations, user avatars and other improvements
Good news for ownCloud users!
Our official integration app for ownCloud has been updated to version 9.1.1. With this release, now you can create and fill out PDF forms, annotate PDF files, recognize other collaborators by their avatars and much more. Read this article for further information about the new features and improvements.
Create and fill out PDF forms
Since the release of version 8.0, PDF has become the standard format for ONLYOFFICE fillable forms. Now this feature is available in the ONLYOFFICE and ownCloud integration. You can create complex PDF forms with interactive fields and fill them out right in your ownCloud platform.
You can create a new PDF form from scratch or turn an existing document into a fillable PDF file. You just need to choose the required option, PDF form or PDF form from existing text file, in the Files module.
Read this guide to learn more about creating and editing fillable forms using the ONLYOFFICE form creator.
Annotate PDF files
Another feature introduced by version 8.0 is PDF annotation. Now you can also annotate PDFs in your ownCloud platform. For example, you can highlight, underline and strikethrough text in your file. Additionally, you can leave comments and draw different objects and lines with the built-in drawing tools.
To annotate a PDF, find the required file, click on it and choose the Open in ONLYOFFICE option. When the PDF file is opened, go to the Comment tab and choose the tool you need.
Choose users to provide access to protected ranges
The updated ONLYOFFICE connector for ownCloud makes it easier to work with protected ranges in your spreadsheets. When using this feature, now you can choose the users who you want to be able to edit a certain range. Additionally, you can even block a range completely so that nobody can make edits to this range.
Where to find: Protection Tab -> Protect range -> New -> Who can edit
Use avatars for more convenient document collaboration
To make the document collaboration more convenient, the updated ONLYOFFICE connector for ownCloud allows you to see other users’ avatars so that you can easily recognize who is working on the same document except you at this moment.
Combine documents from your storage
The document combination feature comes in handy when you need to merge multiple separate documents into a single file. The ONLYOFFICE connector v9.1.1 comes with a new option allowing you to choose files for document combination from your storage.
Where to find: Collaboration tab -> Combine -> Document from storage
Use the offline viewer for shared documents
The updated ONLYOFFICE connector for ownCloud lets you use the offline viewer when sharing documents with external users. With this feature, you can share your files as they are with external users and keep editing them. In this case, external users can access your documents but they won’t see your further modifications until you finish the editing process.
Reference data from co-editing sessions
Using the ONLYOFFICE spreadsheet editor, you can now create external links to certain cells or ranges of cells in other workbooks within the same instance. Such links make it easier to share data between several workbooks.
To add an external link, you need to copy data from the source workbook and paste it into the required workbook using the Paste link option. When your workbooks are linked, you are allowed to choose one of the following options:
- Update values to ensure seamless data synchronization of data between the two workbooks;
- Change source to modify the origin of data retrieval;
- Open source to provide instant access to the file from which data is collected;
- Break link to remove connections between the two workbooks.
Where to find: Data tab -> External links
Other fixes and improvements
- Updated list of supported formats (djvu, dot, dotm, fb2, fodt, htm, mht, mhtml, oxps, stw, sxw, wps, xml, xps, fods, sxc, xlsb, pot, sxi added);
- Added new empty document templates in Arabic and Serbian;
- Adjusted the mobile editor size;
- Added compatibility with ownCloud Web v7.0 and more.
The full changelog is available on GitHub.
Get the updated ONLYOFFICE connector for your ownCloud platform
Make sure you have access to all the new features above by getting the latest version of the ONLYOFFICE connector for ownCloud from GitHub or the ownCloud Apps Marketplace:
Useful links
ONLYOFFICE for ownCloud: website / GitHub
ONLYOFFICE Docs for ownCloud: on-premises / cloud
Guides for the ONLYOFFICE and ownCloud integration: Help Center / API documentation
Other ONLYOFFICE connectors: all options
