How to save a PDF as a picture?
The PDF format is a reliable aid in preserving the integrity of content across platforms and applications. However, sometimes, you may need to save a PDF as picture to extract, convey, or enhance certain visual elements. Read this article to learn several ways to convert a PDF to a picture using various tools.
Method 1. Save a PDF as a picture with a PDF editor
The easiest and fastest way to make a PDF a picture is to do it with a special function of the PDF editor. This way helps you save time, as the task can be accomplished in a few clicks. Besides, you don’t need to search for and use third-party applications. You can convert PDF to picture in editors that support PDF formats, such as Adobe Acrobat, Wondershare PDFelement, and others.
Let’s see how to save a PDF as a picture using the ONLYOFFICE PDF Editor. It is a tool that supports annotating, form filling, commenting, and drawing. It also allows you to save your PDF files in JPG, PNG, EPUB, DOCX, ODT, and other formats.
For quick reference, ONLYOFFICE PDF Editor is part of an open-source office suite that also includes editors for text documents, spreadsheets, presentations, and forms. You can use ONLYOFFICE editors online with a free DocSpace account or get free desktop apps for Windows, Linux, or macOS.
To convert PDF to picture, follow the steps below:
- Open your PDF file in ONLYOFFICE PDF Editor.
If you are using DocSpace, drag and drop your PDF file into the file storage and then double-click on the file to open it in the PDF editor window. In Desktop Editors, open editors, click Open local file and choose your PDF from your PC.
- Review your file.
- If everything is correct, go to the File tab on the top toolbar.
- Click Download as and choose the JPG or PNG format by clicking the corresponding icon. In Desktop Editors, choose the picture format from the drop-down list.
- Select a location on your PC or cloud storage where you want to save the file. Click OK.
- Once done, your file will be saved as a picture.
Watch our video to learn how to save files as a picture in ONLYOFFICE editors:
Method 2. Save a PDF as a picture with an online converter
Another quick way to convert a PDF to a picture is to use a converter that supports both PDF and picture formats, such as JPEG, JPG, or PNG. Such services allow you to quickly drag and drop a file into the conversion area, select the final format, wait a moment, and get the final file as a picture.
When choosing a service to convert files, pay attention to the high quality of conversion and security. If your data is sensitive, use alternative ones, those that are open source, and do not store your files on the server.
Here are some of the solutions you can use.
SmallPDF
SmallPDF is a popular online platform that offers a variety of tools for working with PDF files. It provides a user-friendly interface, a range of features, and the ability to convert PDF documents to various formats, including JPG. Users can easily upload their PDF files and obtain high-quality JPG images in just a few clicks.
As an online tool, SmallPDF allows users to access its features from any device with an Internet connection. This cloud accessibility enhances the usability of the platform.
The tool prioritizes the security and privacy of user data. The platform employs encryption protocols to ensure that sensitive information remains protected during file uploads and conversions.
SmallPDF provides a free version that allows users to perform basic conversion operations.
iLovePDF
iLovePDF offers a dedicated tool for converting PDF files to JPG images. Users can effortlessly upload their PDFs and obtain high-quality JPG files, retaining the visual elements of the original document.
What’s more, iLovePDF offers a comprehensive toolkit for PDF management. Users can merge, split, compress, edit, and even add watermarks to PDF files, providing a one-stop solution for PDF-related tasks.
Apart from the online service, the developers offer iLovePDF Desktop App to work with PDF tools on your Mac or Windows computer.
iLovePDF offers a free plan that includes essential features. For users requiring more advanced features and higher usage limits, iLovePDF provides affordable premium plans. These plans come with faster processing times and priority customer support and start from 4€ per month.
PDF2Go
PDF2Go.com is an online PDF editor that lets you edit PDF documents as well as convert them to many different formats. PDF2Go offers an effortless way to convert PDF files to images (JPG, PNG, and more) to open your image files to a wider audience and easy viewing.
Besides, PDF2Go also allows you to edit PDFs without the hassle of setting up robust software like Adobe Acrobat on Windows, Mac, or Linux.
Data security is ensured by automatically deleting files after 24 hours. The service does not create backups of your files. Since it is an automated process, your files will not be manually controlled by anyone.
FAQ
Why convert a PDF to a picture?
Converting a PDF to a picture can be beneficial for several reasons, depending on the specific needs and preferences of the user.
Easier sharing. Images are generally more accessible and easier to share than PDF files. Converting a PDF file to an image can simplify the sharing process, especially if the recipient does not need to edit the document and a visual representation is sufficient.
File size reduction. PDF files can sometimes be large, especially if they contain high-resolution images or extensive content. Converting individual pages or items to images can reduce the overall file size, making it easier to store or share.
Embedding in documents or presentations. Converting a PDF file to an image allows users to integrate specific content into different types of documents without using additional editing tools.
Use of pictures in social media and online platforms. Pictures are often used on social media and websites. Converting a PDF file to an image makes it more compatible with these platforms, allowing users to share content seamlessly.
Further design and editing. Designers and creatives can convert PDFs to images to use them in graphic design or image editing software.
What is the best format to save PDF to: JPG or PNG?
If the PDF file contains a large number of images with photos or realistic images and you need a smaller file size for Internet use or file sharing, saving it in JPG format is fine. On the other hand, if the PDF file contains graphics with text, and transparency, or requires maximum image quality for printing, saving it in PNG format is preferable. To choose the format that best suits your needs, consider the usage and image characteristics.
Is it possible to convert the picture back to PDF?
Yes, it is possible to convert an image (such as a JPG or PNG file) back to PDF. To do this, you can use the same conversion services as above.
