ONLYOFFICE and Seafile integration: edit documents on Android devices
Now you can easily edit docs in the ONLYOFFICE Documents app on Android devices and synchronize the changes with your Seafile portal. Learn all the details below.
Mobile integration: how it works
Our partners from Seafile implemented the Shared Folder functionality in their Android app. It means that you can edit office documents using other apps, including ONLYOFFICE, and all the changes will be automatically synchronized with your Seafile portal.
You don’t even need ONLYOFFICE Document Server to be installed to work with Seafile documents on your Android device.
To be able to benefit from this mobile integration, install ONLYOFFICE and Seafile apps from Google Play:
DOWNLOAD ONLYOFFICE DOWNLOAD SEAFILE
Then, log in to your Seafile server in the Seafile mobile app. When you try to open any document, the device will ask you what application to use — just select ONLYOFFICE Documents and make the necessary changes in the file.
After saving the changes, you will see the modified documents are synchronized with your Seafile portal opened in the web:
Please note: in case you want to edit office documents in the web version of your Seafile, you need to install ONLYOFFICE Docs and connect it to Seafile.
About Seafile
Seafile is an enterprise file sync and share solution with high reliability and performance developed by Seafile Ltd., a company based in Beijing, China. Designed as a reliable cloud file storage and collaboration platform, Seafile provides a similar feature set like well-known cloud storage providers, while it allows users to host the server on their own hardware.
The core feature of Seafile is file sync and share. It offers client apps for most operating systems like Windows, Mac OS, Linux, iOS and Android. It also provides a user-friendly web interface for accessing files via the web browser. The community edition of the Seafile Server is completely open-source.
Useful links
Connect ONLYOFFICE Desktop Editors to Seafile
SmartLynx Airlines deployed ONLYOFFICE & Seafile
Take part in a survey and help us improve ONLYOFFICE mobile apps
