How to make calendar in Excel sheet
9 July 2021By Vlad
Excel calendar templates are sometimes simply not enough. In this article, you‘ll learn how to create custom weekly, monthly, and yearly calendars from scratch in ONLYOFFICE.
Why make a calendar in spreadsheets? It is easy, free, and lets you add any necessary element for comfortable planning. Once created, the calendar can be used as a custom template for various tasks. The core format is XLSX, which makes the output file compatible with Office 365.
You can share calendars with colleagues to add events together or inform clients about free time in your schedule.
Just sign up for ONLYOFFICE Workspace or ONLYOFFICE Personal to create calendars online. Get ONLYOFFICE Desktop Editors for offline spreadsheets on Windows, Linux, and macOS.
Excel weekly calendar
This option is suitable for appointing meetings, planning posts in socials, tracking football fixtures, and scheduling deadlines. Weekly calendars give you a detailed overview of workload for the next 7 days and let you set time.
Follow these steps to make your own weekly calendar template for Excel.
Step 1. Create a new spreadsheet and go to B1. Input the first day of the week — Monday or Sunday. Horizontally add the other days — in our case Tuesday will be in C1, Wednesday in D1 and so on. Leave out the weekend, if you don‘t need this schedule for personal tasks.
Customize the font of this row to your taste.
Step 2. Enter the hour when you start working in A2. Extend the column with time values you need — full hour, half hour, fifteen minutes etc. The last cell in the column will indicate when it is time to close your laptop.
Play with colors, bold, or italicize the fonts for the time.
Step 3. Highlight all values in the spreadsheet and click on Wrap Text to avoid longer texts overflowing to other cells.
Done! Input your first events and start planning.
Excel monthly calendar
Such calendars are good for planning trips, trainings, diets, and even tracking personal budget. They are most widely used and let you gain insights about productivity, reconsider goals, and analyze payment frequency.
Here is how we make a monthly calendar in an Excel sheet:
Step 1. Create a new spreadsheet, enter days of the week to the first row and customize their size, fonts, and alignment.
Step 2. Let‘s make columns from A to G wider. Select and right-click them, go to Adjust column width —> Custom column width, and set the desired value.
Do the same to the height of rows from 1 to 6. Leave enough space here — each cell is a day in your future calendar.
Step 3. Add numbers of the days to the rows and align them to your liking. We recommend to keep numbers to the top-right corner, so that you have enough space for events and notes.
Step 4. Copy the sheet to create a separate one for each month. Fix the dates and remove 31 from April, June, September, and November. Make 28 days in February (29 in a leap year).
Done! Plan your month and mark completed tasks with a color.
Custom yearly calendar
This type of a calendar gives you a broader overview of the whole year. It is suitable for planning big events, such as birthdays, exams, vacation, accounting reports etc. You can track implementation of long-lasting projects, for example market research.
Let us compile a yearly calendar in an Excel sheet from scratch:
Step 1. Create a new spreadsheet and go to B1. Horizontally add all months — January in B1, February in C1, March in D1 and so on. Customize the font of this row to your taste.
Step 2. Enter days of the month to the first column starting from A2.
Step 3. Let‘s make columns from A to G wider. Select and right-click them, go to Adjust column width —> Custom column width, and set the desired value.
Select the whole working area and click on Wrap Text to avoid longer texts overflowing to other cells.
Customize your annual planner with different styles.
Note: Remember to cross out 31 from April, June, September, and November. Make 28 days in February (29 in a leap year).
Easy, right? Schedule your whole year and gain insights about the workload.
Want to make your custom calendar in an Excel sheet without a template? Get free ONLYOFFICE Workspace or desktop app for Windows, Linux or macOS.
START IN CLOUD GET DESKTOP APP
Get free ONLYOFFICE Personal for making custom calendars online.
Free calendar in ONLYOFFICE Workspace
In ONLYOFFICE Workspace you can create personal and group timetables, share calendars, and set reminders. Weekly, monthly, and yearly calendar in one module! It is closely integrated with CRM and projects on your portal — track your progress seamlessly online.
You can integrate third-party calendars using the CalDAV protocol to have all events at hand. ONLYOFFICE Workspace is free for up to 5 users.
