Editors in ONLYOFFICE 9.6 come with EasyBib and WordPress
20 March 2018By Ksenija
Hello everyone!
Version 9.6 is out and there is some great news to share with you. Among multiple improvements, the update gives you two amazing plugins for working with bibliography and publishing texts directly to WordPress.
9.6
What is EasyBib and how it works
This helpful plugin is an instrument for automatically adding the references in full accordance with style guides of your choice, be it Harward, IEEE, Chicago or any other.
Find the desired book, article or website using the search tool in the plugin sidebar, then add it and select the necessary bibliography style. After that, put the cursor in the document where you want the list to begin and click ‘Add Bibliography to Doc’ button in the plugin sidebar.
EasyBibplugin1
To use EasyBib in ONLYOFFICE, you must configure the service on your portal in third-party services menu. The detailed instruction can be found in our Help Center.
How to publish from ONLYOFFICE to your WordPress website
If you have your own WordPress website, from now on you can publish documents as articles directly from the document editor. To do this in the cloud service, you just need to log in to your WordPress acсount in the plugin. Configuration in the server solutions requires a few additional steps that are described in Help Center.
wordpress-onlyoffice
Note that objects including images, autoshapes, and tables cannot be transferred to WordPress due to inner specifics.
The plugins are already available in our cloud service and private server solutions and are coming soon in the other products.
Visit portal
We are continuously improving our functionality and if there are any minor issues that occur with the plugins, just tell us and we will fix them very soon. You are welcome to try ONLYOFFICE 9.6 and leave your impressions in comments below.
